Write Out Data To Excel
  • Sep 12, 2022 12:25 PM UTC
  • 405 views
Hello everyone,
i want to read out Data from my project to excel. In Order to do so i created the following code:
if not axll::WorkBookIsOpen(WorkbookFilename : "data//Auswertung_Szenario2.xlsx" ) then
        axll::OpenWorkBook(WorkbookFilename : "data//Auswertung_Szenario2.xlsx" );
endif;
axll::SelectSheet(SheetName : "Tabelle1" );
axll::WriteTableQuick(
        IdentifierReference : LeadTimeOfOperation ,
        TopLeftCell         : "A5" ,
        RowDimension        : 1,
        WriteZeros          :  0,);
I dont get any error codes when i run the Procedure and the LeadTime Parameter is also not empty, but in my Excel Sheets i still cant see the Data.
Does anyone know why that could be the case ?
Kind regards
Alex
Best answer by AlexK
Hi!
Tried to reproduce your example, but, to use axll::WriteTableQuick the parameter needs to be with one dimension or more. With no dimension, I received an expected error. Did you tried axll::WriteSingleValue(ScalarReference,Cell) ?
Either way, in this example I used both import and export with AXLL library. Check this (https://github.com/aimms/knapsack) out!
i didn´t think about specifying that but the reference parameter is actually indexed. Its LeadTimeOfOperation(i). I just didnt know i had to write that in this part of the code aswell since it didnt give an error message. Now i tried it and it works.
Thank you.
Hi!
  • Sep 12, 2022 4:04 PM UTC
Hi!
Thank you.
