DEMO
New Widgets and Features for GIS Location Data
  • Jan 26, 2022 3:32 PM UTC
  • Jan 31, 2022 11:53 AM UTC
  • 892 views
We have improved our GIS Location Data page to make it easier to check your geolocation!
  • A Country Filter has been added to the page GIS Location Data in order to allow the filtering of locations by country.
  • An additional attribute (Country Code) has been added to the data when you indicate that you want to retrieve data from Location IQ. The country code should come from ISO 3166-1 alpha-2 codes. This new attribute is useful in combination with the Postal Code attribute.
  • Data Navigator will use a specific postal code logic when both the Postal Code AND the Country Code are provided. This new logic should provide better results.
  • The Location Table on the page GIS Location Data has four new widget actions as well as some additional output data which can be compared to the input data in order to determine the quality of the results.
  • If your dataset has more than 2500 locations, the map on the page GIS Location Data shows initially only the first country; however, the side panel is open by default, such that the current view becomes more clear. This feature is meant to improve performance.
Below there's a video of how to use these new features and where to find the widgets.
