Centering Title in Table Widget
  • Jul 3, 2024 9:10 AM UTC
  • 74 views
This is what it is:
And this is how I want it to look like:
Seems like entering empty spaces at the beginning of the String doesn’t work. Any ideas on how to do it?
Best answer by gdiepen
One way would be to add some css that will center the h2 node holding the title
Adding the following custom css to your project:
.aimms-widget[data-widget\.uri="mydemotable"] h2.title-addon{
margin: auto;
seems to do the trick:
Note that you will have to replace the “mydemotable” in the above code with the name of your widget.
  • Jul 3, 2024 10:21 AM UTC
margin: auto;
  • Ace
  • Jul 3, 2024 12:18 PM UTC
Hi @gdiepen,
Thanks, it works. To add to this for a further reference for future, I just found out that left margin can also be customized as follows:
margin-left: 3cm;
Gorkem
