Changing the data color in table regardless of being editable or not
  • 27 June 2024
  • 45 views
Userlevel 1
Badge +3
As you know, cell values are shown black when they are read-only and blue otherwise as given below.
I would like to be able to set a specific text color, regardless of whether it is read-only or not. I wonder if there is a way to do it?
P.S. I know we can change the background color in a cell with annotation but there are times where I need to change both the background color and the text color.
Best answer by gabiservidone 11 July 2024, 22:44
Badge +6
In the Contract Allocation example, I used background annotation, theme to change the font color when editing and a custom css to change the font when there are default data: https://how-to.aimms.com/Articles/383/383-contract-allocation.html
But more specific to your current problem, use this color variable to change from AIMMS blue to any other color you’d like: --color_text_edit-select-link
Userlevel 1
Badge +3
Hi @gabiservidone ,
Thanks, this information helps me to some extent, but what I really want is : you know we can give condition-based specific background color to cells by defining a string parameter and using it as annotation identifier. I am wondering if we have the same flexibility for text color in the cells.
Best,
Gorkem
Badge +6
Gotcha, yes, it is possible. As you know, for background annotation, the CSS code would be:
.annotation-reach-maximum {     background: red; }
To change the background and the font color using same annotation, the CSS code would be:
.tag-table .grid-viewport .annotation-reach-maximum {
    background: red;
    .cell-wrapper {
        color: whitesmoke;
