Create project with Excel file
I would like to create a project with AIMMS about transport problems. All my figures are in an excel table. How can I rearrange my table for use in AIMMS?
I have successfully added the AIMMS tool to my Excel spreadsheet.
Thank you in advance.
Best answer by Jess Es
Hi @Steve Randy
You may want to look at using the AIMMS Excel Library (axll) functions https://how-to.aimms.com/Articles/85/85-using-axll-library.html (also  https://how-to.aimms.com/Articles/197/197-reading-data-from-excel.html )
This should give you enough flexibility to read in the parts that you want to use without much rearranging.
I should note that I’m a docs specialist, not support specialist - but this should help you get started anyway :)
Jess Es
  • Grand Master
  • April 3, 2020
Hi @Steve Randy
  • April 5, 2020
Hi @Steve Randy , the suggestion @Jess Es provides you allows you to , from AIMMS read data into your model and write back data to Excel.
Thanks for your advices :)
