Creating simple input / textbox using compact scalar
  • Aug 14, 2026 7:01 AM UTC
  • 10 replies
  • 90 views
Hope anybody has a quick solution for something I have not been able to solve yet….
My goal is to have a scalar widget that uses (almost) all of the available width for the textbox.
So what I have is a string parameter and I show it in a scalar widget for which I enabled compact mode and it shows it like this:
As you can see, there is the … to indicate the full string parameter is not shown. I do not want to show the label spMyStringParameter. Even if I delete that label in the developer console of the browser, the actual input box still does not use the full width.
Is it somehow possible with adding some CSS to have the input box use the full width of the widget (as a single line, I do not want a multiline textbox)
Hi ​@gdiepen and ​@Joost,
Here’s one way to achieve the intended behavior using the Compact Scalar settings together with some custom CSS.
A Compact Scalar widget.
 Then, set the Show Labels option to 0 for the widget.
Finally, add the following custom CSS to your application:
.aimms-widget[data-widget\.uri="{Your_widget_URI}"] .kpi .value .cell-wrapper {
flex: 1 !important;
justify-content: flex-start !important;
.aimms-widget[data-widget\.uri="{Your_widget_URI}"] .kpi .value .cell-wrapper label {
flex: 1 !important;
Don’t forget to replace the text `{Your_widget_URI}` with the actual URI of your widget.
This should give you the desired textbox-like behavior while still using the Compact Scalar widget.
Hope this helps!
Madhu Krishnappa
  • Aug 21, 2026 7:44 AM UTC
Nobody having the same need to have the actual input text box use the full width of the white area?
  • Ace
  • Aug 24, 2026 9:54 AM UTC
You are not alone :)  I also like that have this
  • Ace
  • Aug 24, 2026 11:41 AM UTC
use Label?
  • Aug 24, 2026 12:31 PM UTC
As far as I know a label is a readonly widget?
I want the user to have just a textbox that is the full-width of the parent component it is in and does not have any internal blocked areas
  • Aug 24, 2026 2:33 PM UTC
I found one other way, namely using a table and hide the row and col headers, but this seems a bit of a duct-tape solution to me….
  • Ace
  • Aug 24, 2026 3:17 PM UTC
yes true and agree
Madhu Krishnappa
flex: 1 !important;
flex: 1 !important;
Hope this helps!
Madhu Krishnappa
  • Aug 26, 2026 6:59 PM UTC
Awesome! Will give this a try tomorrow!
Thank you for the extra css information
Madhu Krishnappa
Hi ​@gdiepen,
Just wanted to check in, did you get a chance to try out the CSS + "Show Labels" tweak? Did it get the compact scalar's textbox filling the full width as expected, or are you still running into truncation issues?
Let me know how it goes, happy to help further if it's not quite there yet.
Madhu Krishnappa
  • Sep 3, 2026 9:37 AM UTC
Hi ​@Madhu Krishnappa
That does indeed what I wanted it to do. I did also add text-align to the left instead of the default centered
