Editing widget table with multidimensional data
  • May 21, 2024 11:56 PM UTC
  • 48 views
yasmany
Greetings comunity;
recently i was trying to work on MOPTA solution and we have a problem with multidimensional paramaters edit in web UI; is there a way to edit a widget table with multidimensional data.
Thanks for help
Best answer by gabiservidone
Hi @yasmany!
Yes you can! If you added your multidimensional parameter to a Table Widget, you should already be able to edit it. If you are not being able to edit, check if your parameter has a definition, defined parameters are not editable.
Hi @yasmany!
