Empty space workflow
  • Oct 7, 2019 11:58 AM UTC
  • 5 replies
  • 171 views
Is it possible to create some empty space in the workflow panel?
I want to put the "result" page at the bottom of the workflow.
Best answer by Pratap Kumble
Hi @OlmoVerhagen,
You can achieve this with Custom CSS.
  1. Create a page, lets say Workflow Step Hidden, in the page manager.
  2. Hide the page from the navigation via the Visibility option.
  3. In the string parameter you use to define the steps, create some steps with only data filled for the pageId = workflow_step_hidden and workflowPageState = Inactive
  4. Create a Custom CSS file and add the below code to the file:
code:
.workflow-panel .step-item[data-page-id="workflow_step_hidden"] {
visibility: hidden;
Data would look like:
You should see the following result:
Please let me know if this worked.
Pratap
Patrick
  • Administrator
  • Oct 7, 2019 2:24 PM UTC
We are having a look @OlmoVerhagen, expect an answer the coming days.
  • Oct 11, 2019 10:42 AM UTC
Hi @OlmoVerhagen,
code:
visibility: hidden;
Pratap
  • Oct 16, 2019 7:53 AM UTC
Thanks for your answer! WIll test in next week :)
  • Oct 17, 2019 11:55 AM UTC
It’s working!
Patrick
  • Administrator
  • Oct 17, 2019 11:57 AM UTC
Would love to see the result one day @OlmoVerhagen!
