Error in WebUI when using OneDrive
  • Mar 2, 2020 8:59 AM UTC
  • 237 views
When I create a project in a folder, which is synced by OneDrive, and I try to add a widget in the WebUI, I get the following error message: “awf.state: Problem writing ‘MainProject/webui.json’ on the server (500: boost::filesystem::create_directory: Eine Datei kann nicht erstellt werden, wenn sie bereits vorhanden ist: [...])’ (translates to: “a file cannot be created when it already exists”). I can continue working in the WebUI, but when I close the project, all my work is lost.
I do not experience the problem, as soon as I move the complete project folder outside of OneDrive.
Does anyone else have the same problem?
AIMMS version: 4.71.6.8 (64-bit)
@Benedikt , what are your OneDrive sync settings ?
Default settings of OneDrive is to download files as you use them, so there is a physical copy of only those files which it thinks are being used on your laptop. This does not always work well with an AIMMS project which is a collection of files and folders.
If you change your settings to always keep copies on your laptop, you shouldn’t have any problem. Below is my OneDrive settings and I work on AIMMS projects in this directory. However, it is recommended that you don’t start a git repo in a OneDrive folder.
  • Mar 20, 2020 11:19 PM UTC
  • Mar 26, 2020 8:31 AM UTC
Thank you for sharing your settings with me, @mohansx. After changing my settings I don’t get the error message anymore.
