Error using webUI (fail to load all objects)
  • Feb 2, 2023 10:23 PM UTC
  • 180 views
Forum|alt.badge.img+1
I am working on a model and tried to use WebUI to analyze some results.
However, when I tried to open the WebUI, the system says it failed to load all objects with the error message below.
  • awf.data.aimms.session: Running requestGetIdentifierValues for [object Object] has resulted in an error: Unable to retrieve values for all identifiers (code=400)
I re-started the AIMMS project, but it didn’t help.
Anyone know potential reason for this error?
It would be very appreciated.
Thank you
Best,
Best answer by gabiservidone
@djdmlwns can you send a message to support@aimms.com for me to test this problem with you?
  • Feb 3, 2023 3:45 PM UTC
I found out the reason of the error.
When I initialize, I intended to remove all parameters that I read from other files because in the initialization procedure, there are some steps to read these data.
However, used “empty” statement, which removed all other webui related pre-determined parameters.
Thank you very much for your reply anyway
