How can I change the look and feel of the busy spinner?
  • June 13, 2019
  • 243 views
MathFour
AIMMS Partner
My WebUI app is looking mighty spiffy. However, whenever AIMMS takes an extra second or two, I see this blue busy spinner.
Alas, that is not in my color scheme.
How can I change either the color of the spinner or the .gif itself so that the spinner matches my look and feel?
Best answer by Pratap Kumble
Hi @MathFour ,
Please try the following style:
/* to change the color of the busy text */
.theme-aimms .veil-msg .msg-body {
color: red;
/* to change the loader image */
.theme-aimms .veil-msg{
background: grey url("../images/dotloader.gif") no-repeat 25px;
height: 150px; /* if you want to change the height of the busy bar. */
/* to change the color of the cancel button on the right */
.theme-aimms .tag-veil .veil-msg.state-busy .ui-button{
background:green;
the image needs to be in the /resources/css/images folder.
The current loading image is a 50x50 px image.
Do let me know if this helped.
Thanks.
Hey MathFour,
The busy icon is an gif located in C:\Users\...\AppData\Local\AIMMS\IFA\Aimms\4.67.5.0-x64-VS2017\WebUIDev\www\resources\images depending on which AIMMS version you are using.
The default for the AIMMS version I'm currently using is busy_610467c49e28b4e0fc620c1e8336555b.gif which is blue. To change this, I suggest you to download something in your system's color scheme and change the referenced gif in the css class below.
.theme-aimms .veil-msg {
opacity: 1;
height: 50px;
background: #f5f6fa url(../../resources/images/throbber_5e55c38….gif) no-repeat 25px;
text-align: left;
padding-left: 74px;
color: #505767;
MathFour
AIMMS Partner
  • June 14, 2019
Thanks @gabiservidone, however it doesn't work. I even tried changing the name of my gif to the name of the blue one, but it still picks up a runtime gif somehow.
Other ideas?
  • June 21, 2019
Hi @MathFour ,
color: red;
background:green;
Thanks.
