How can I change the map node shape?
  • Dec 3, 2020 3:59 PM UTC
  • 305 views
I was wondering if it is possible to change the shape of the node on the map from a circle to something different, e.g. a square or triangle? I am already using color coding to indicate allocation of store locations to warehouses, the shape is intended to differentiate between 3 different types of stores.
Using of icons or alterntative stroke colors doesn't really work, because the nodes need to be quite small. But I am also interested in any other suggestions to make it work.
Best answer by Pratap Kumble
Hi @tbulavskaya ,
Currently, there isn’t an option to change the shape of the node. We do have it on the roadmap but it might take a while to get to.
However, there is a workaround. Since you are already using annotations for color there are just two things you need to do.
  1. Add icons to the nodes. you can find all the icons here - https://manual.aimms.com/_static/aimms-icons/icons-reference.html
  2. Add the below CSS (please change the annotation names and the colors as required)
/* Only icons without node AND Color to icons */
.annotation-red .node-icon:before{
color: red !important;
.annotation-yellow .node-icon:before{
color: yellow !important;
.annotation-green .node-icon:before{
color: green !important;
path.annotation-red,path.annotation-yellow,path.annotation-green{
display: none;
/* ----------End---------- */
You should be able to get a similar effect as the below image.
I also added a node size parameter to increase or decrease the size of the icon. For the example I used a node size of 10.
Please let me know if this works.
Pratap
  • Dec 4, 2020 7:46 AM UTC
Hi @tbulavskaya ,
display: none;
Pratap
  • Dec 4, 2020 8:32 AM UTC
Thanks Pratap, that really helps! I have done a small test and it works indeed.
I am used to coloring nodes on the map with the following css:
.tag-mapv3 .annotation-red{
fill: red;
stroke: red;
But if I use your version with node-icon, my code becomes irrelevant, right?
In a way yes. the below CSS hides the node but retains the icon:
display: none;
You can remove or comment the code you have.
