How do I empty a selectionbox in version 4.77 or higher?
  • Jul 21, 2022 11:47 AM UTC
  • 191 views
I see in the release notes that the default value of a parameter is now only available if it is specified.
However, I always use this option to empty selection boxes. I tried addding '’ as a default value, but that still does not allow me to select the “Default:: “ option in the dropdown.
So my question is “What should I now do to empty my selectionbox (and show the data for all possible values of the parameter - instead of only for the selected value (location in my case)?
Best answer by gabiservidone
@Brn the solve will take a while to be available, but we do have a way around for the mean time.
Click on the cell you want to empty, and press the delete on your keyboard. This will empty the value.
Hey @Brn,
I tried to reproduce here (using 4.85) and this is what I have as result.
First is using an element parameter, second using a idexed parameter. As you can see, both has an ‘x’ in the right corner, if you click there, it will empty the value. Is this what you needed? If not, can you share the problem again with some screenshots?
  • Aug 18, 2022 10:54 AM UTC
Hi @gabiservidone, thanks a lot.
I see the cross in selection boxes now.
However, I also have a scalar where I do not see this cross:
How can I empty the selection here?
(still testing in version 4.77 btw)
@Brn, found the same behaviour here.
I will work with the WebUI team to resolve this issue, when it is done, we let you know!
