How to change specific table identifier (checkbox) to a image/button
  • Mar 3, 2020 6:05 PM UTC
  • 5 replies
  • 444 views
mateusarakawa
Hello everyone.
We are trying to change a specific identifier in our table to a button that opens a dialog page.
It’s the last column within this table:
However, as you can see in the image, our CSS styling is applying this change to all checkboxes within the table:
.tag-table[data-widget\.uri*="tbl_PlanoOperacional_Tratos"] .cell-wrapper input[type=checkbox][class*=boolean] + span{
background: white url(images/floppy-disk_roxo.png) no-repeat 50%/contain;
We have already tried to change it using annotations, but we weren’t able to make it work out.
Is this possible? Thanks!
Hi @mateusarakawa , did you try the annotation selector before the cell-wrapper ?
.annotation-showimage .cell-wrapper …
I did this in my sample project and only the identifier with annotation as showimage is modified via css, not impacted by moving the column/row around.
This is my code to restrict this only to the identifier with annotation showimage, in table newtable.
.tag-table[data-widget\.uri="newtable"] .annotation-showimage .cell-wrapper input[type=checkbox][class*=boolean] + span {
mateusarakawa
  • Mar 3, 2020 6:13 PM UTC
Maybe the answer to my question is the same as we had in another topic:
https://community.aimms.com/aimms-webui-44/how-to-change-unit-and-decimals-by-parameters-532#post1340
mateusarakawa
  • Mar 3, 2020 6:38 PM UTC
 Update: We were able to make it work, but our CSS code is way too hard-coded. It references to the “col9” class that aimms creates to this identifier. If we change the position of this identifier within the table, we’ll lose its format.
.tag-table[data-widget\.uri*="tbl_PlanoOperacional_Tratos"] td[class*=col9] .cell-wrapper input[type=checkbox][class*=boolean] + span {
  • Mar 4, 2020 8:01 PM UTC
mateusarakawa
  • Mar 5, 2020 2:34 PM UTC
Hi, @mohansx . Thanks, it worked!
Somehow we messed up something when we added the annotation reference to the css file.
  • Dec 9, 2022 3:33 PM UTC
It is not completely clear to me, but is it possible to use this icon/button to trigger a procedure in AIMMS?
Would it be possible with some version of the above to style an icon/button in a table based on some identifier from the model and have AIMMS open another page whenever this icon/button is clicked (where which  page to open is coming also from the model)?
