I want to change the tooltip that appears when the cursor is over the 'codigo_fornecedor' set. The tooltip identifier changes the tooltips of each element in the set, but not the title attribute.
Hi
You can use the predeclared identifier webui::IdentifierTooltip
to display a custom tooltip when hovering over these Identifiers.
It's important to note that the value of webui::IdentifierTooltip
on an index is what matters (not the value of webui::IdentifierTooltip
on the Set which is the range of that index). This means that if a set has two or more indexes, each index can have a different tooltip name based on the string value of webui::IdentifierTooltip
applied to that index.
Similarly, through predeclared identifier webui::IdentifierElementText
you can apply a custom display text for these Identifiers.
Please refer to this documentation for more details.
Do let us know if this helped.
Madhu Krishnappa
