How to change the tooltip from a set in a table
  • June 7, 2024
  • 90 views
I want to change the tooltip that appears when the cursor is over the 'codigo_fornecedor' set. The tooltip identifier changes the tooltips of each element in the set, but not the title attribute.
Hi @Laura Lessa,
You can use the predeclared identifier webui::IdentifierTooltip to display a custom tooltip when hovering over these Identifiers.
It's important to note that the value of webui::IdentifierTooltip on an index is what matters (not the value of webui::IdentifierTooltip on the Set which is the range of that index). This means that if a set has two or more indexes, each index can have a different tooltip name based on the string value of webui::IdentifierTooltip applied to that index.
Similarly, through predeclared identifier webui::IdentifierElementText you can apply a custom display text for these Identifiers.
Please refer to this documentation for more details.
Do let us know if this helped.
Madhu Krishnappa
Madhu Krishnappa
Hi @Laura Lessa,
Madhu Krishnappa
