How to change the WebUI display name of a parameter/set?
  • September 2, 2021
  • 416 views
In my projects I like to use prefixes such as ‘s_’ for sets and 'p_’ for parameters.
However, when designing a webUI page, I would like to mask these names with something more human-friendly. How do I do this?
My minimal working example project contains two items:
Set s_DummyData {
Text: "SetDescription";
Index: i_dummy;
Definition: {
DATA {1 .. 100};
Parameter p_SampleParam {
IndexDomain: i_dummy;
Text: "ParamDescription";
Definition: {
val(i_dummy) * 100;
What I hoped the Text attribute would do, is replace ‘s_DummyData’ with ‘SetDescription’. Instead I see this when I enter a table in the WebUI:
Best answer by Pratap Kumble
Hi @LowBjorn ,
You can achieve this by add a “translation.properties” file in your “MainProject\WebUI\resources” folder.
You can edit the “translation.properties” file in any text editor, and just add the translations there. I’ve attached the file for your reference.
Here is a link in the documentation as well - https://documentation.aimms.com/webui/multi-language.html#project-specific-translations
Please let us know if this worked for you.
Thanks.
Pratap
Hi @LowBjorn ,
Thanks.
Pratap
  • Ace
  • September 3, 2021
@Pratap Kumble Amazingly simple, the example file and the documentation are exactly what I need. Thanks!
