How to Create Scatter Plots in WebUI?
  • Nov 22, 2019 9:05 AM UTC
  • 5 replies
  • 236 views
Dear community,
how can I make scatter plots in WebUI?
I appreciate any help in advance
Best answer by Anonymous
Hi Gergerly,
By default, the Bubble Chart takes a relative size (and a default size if all node sizes are the same). By adding a WebUI annotation to the node and using this to adjust the node-size for this specific set of nodes via Custom CSS, you can create a scatter plot.
Below you see the same info: Left as Scatter, Right as regular Volume Bubbles. I also attached the project where I added the following as custom css:
circle.annotation-scatter-plot.chart-item.bubble {
r: 3px;
fill: blue;
Enjoy
Jess Es
  • Grand Master
  • Nov 22, 2019 8:35 PM UTC
Hi @Gergely Vadler you may want to try using a bubble chart to achieve that https://documentation.aimms.com/webui/bubble-chart-widget.html
Andrew
  • Dec 3, 2019 11:31 PM UTC
Hi @Gergely Vadler
Was the answer provided able to help you with your question or were you able to find your own solution?
Thanks
Hi Andrew
It was a general question, not related to a specific problem.
  • Dec 4, 2019 2:42 PM UTC
Hi Gergerly,
r: 3px;
fill: blue;
Enjoy
Thank you very much
