I have a String parameter for BeginDateofCalendar which takes a string of date.
I created a procedure for getting value for the above string parameter using DialogGetDate which gives me option to select a date from Calendar.
But it only working in WinUI.
When i am running the procedure in a page in WebUI its running but the calendar is opening in AIMMS App, not in WebUI.
what should i do so that the calendar opens in WebUI and not in AIMMS App?
Best answer by Chris Kuip
