How-to
How to upgrade WebUI Maps to new version (for AIMMS v.4.61 and later)
Jess Es
In AIMMS 4.61 we released a new version of the Map widget.
The new version gives several benefits over the previous version, including the following capabilities:
  • Use multiple arc sets and multiple node sets.
  • Hide the labels on the arcs.
  • Display the arcs as straight lines instead of curved ones.
When using AIMMS 4.61 and higher, existing Map widgets in your apps will remain the old version (V1) but any new Map widgets added are in the new version (V2).
AIMMS releases on or after October 1, 2019 will not support projects using the older version of this feature.
To use AIMMS versions released after that date, you will need to be sure that you have upgraded any pages in your WebUI app using Map widgets.
Read more...
