HTML IN AIMMS
  • May 12, 2023 8:26 PM UTC
  • 88 views
Hi there
Is there any possibility to input HTML in AIMMS?
Because I was trying to make a new layout there
Thank you
Edo Nijmeijer
Hi Jon, great to find you here, looking for answers.
The most linear and only answer to your question is the Text Widget: https://documentation.aimms.com/webui/text-widget.html#text-widget
It is the only thing, apart from tooltips perhaps, that accepts html, also when specified as a String parameter. But always with the restraints/filtering that the text editor also applies: so structural elements are mostly out of the question, silently.
So I think it’s better to ask you what ‘layout’ you’re trying to achieve then. And why you maybe feel like a custom Grid Layout could not work for you. Can you describe or sketch it?
