Is is possible to add a label to a bar chart widget?
Looking to this picture, it is not clear if the supply in Hamburg is 68/69.
I would be happy with the following labels:
(and also the legend would be great)
Best answer by Mischa
A quick reaction, as a kind of ‘half’ solution to this: are you aware of the tooltips? If you hover a bar, the WebUI will show you the accurate value in a tooltip that appears. See this example:
It is also possible to override the default tooltips by your own. This even allows you to use HTML.
Regards,
Mischa
