page id not found
  • Apr 23, 2024 9:19 AM UTC
  • 86 views
app is working well in development environment. after publishing app on AimmsPro, I see error as page id not found.
Best answer by ashokpoluu1
it was AIMMS version mismatch error. it is solved now
Edo Nijmeijer
With the PRO environment being Linux-based, you might run into the case-sensitivity that comes with it. Are you sure that all items (the page ids involved) are written, defined and referred to in the exact same manner?
  • Ace
  • Apr 24, 2024 2:03 AM UTC
Edo Nijmeijer
Indeed, it is pretty easy to overlook the version of your local AIMMS IFA and to end up using a different version once you publish it within the PRO Portal.
Often, that does not have to be a problem. Especially if the AIMMS version in the cloud is newer.
If you ran into this problem while using a newer version of AIMMS in the cloud, then I’m curious to know if you managed to understand which functionality might have been causing your error. Just for the record.
And if you fixed your problem by publishing the App with a newer AIMMS version, then I do indeed consider this fixed ‘as expected’. Thanks for reporting back, Ashok.
