page lag when changing authorization
  • Jun 10, 2024 1:51 PM UTC
  • 41 views
Hi Community,
I have the following ‘simple’ situation. I have a editable parameter set by
webui::IdentifierAuthorization(IndexIdentifiers | IndexIdentifiers in xxx) := webui::AuthRWX which is defined in a table on the WebUI. The parameter has also some data.
Now I change the authorization to (via a procedure)
webui::IdentifierAuthorization(IndexIdentifiers | IndexIdentifiers in xxx) := webui::AuthRX and the webui table becomes empty. When I press F5 again, the parameter appears in non-editable state. So functionally it works, but I would like to know how to avoid to refresh the page.
I tried webui::RefreshAllWidgets after setting the authority, but this does not work.
Does anyone have any idea why this happens or how to avoid this?
Cheers
Marc
Using AIMMS 24.5.2.2
Hi @Marc Wingender, can you send this question to support@aimms.com? I’d like to do a more in depth understanding of this problem with you.
