I have a string parameter as axis label for the X-axis and Y-axis of a bubblechart.
When I hover over the axis, I see this same string parameter as tooltip. Is there a way to have a tooltip different from the actual string parameter value? I tried XXX_Tooltips, but that doesn't seem to work (unsure if this works for string parameters at all).
thanks,
Tooltip on axes for bubblechart
There doesn't seem to be a way to override/edit the tooltip but you can completely disable it using CSS.
.y.label for the y axis label.
View originalcode:
.tag-bubblechart .x.label{
pointer-events: none;
