WEB UI does not save
  • Jun 15, 2022 12:38 PM UTC
  • 134 views
For a university project we use AIMMS to solve a model, we also would like to use the WEB UI, however after building the WEB UI it does not save. Why does it not save, is it because we have an academic license? In the AIMMS model the module 'AIMMSWEBUI [read only]' has the property no save, however since it is read only, we are not able to change it. Is there a solution for this problem?
Kind regards!
Best answer by IDontUderstandWEBUI
Settings → Action on leave = procedure: save
Jess Es
  • Grand Master
  • Jun 21, 2022 4:22 PM UTC
Hi @IDontUderstandWEBUI , sounds like you figured it out on your own :)
If you’re looking for more WebUI resources, you may want to check out our Academy, where we have a course called Basics: My First AIMMS App to guide you through the fundamentals
