How to connect AIMMS with SCIP Solver
  • October 19, 2021
  • 119 views
There is a solver Solving Constraint Integer Programs (SCIP). https://scipopt.org/doc/html/index.php#WHATISSCIP
How to connect it to AIMMS?
I’m trying to add libscip.dll via Solver Configuration, but recieve an error.
Hi @bacherikov_iv , There exists no interface between AIMMS and SCIP, and therefore you cannot use SCIP in AIMMS. Adding a SCIP dll in the solver configuration will not work.
Connecting SCIP to AIMMS would require building an interface using the AIMMS Open Solver Interface, which is a lot of work. At AIMMS we currently have no plans for building a link to SCIP.
  • November 1, 2021
As a workaround you can just write your instances out in one of the many format that can be read by SCIP, such as .lp or .mps.
