How to Connect to Access database file
  • March 28, 2019
  • 205 views
User Support
AIMMS has the possibility to retrieve/store data from/into any ODBC or OLEDB datasource. You could provide a UDL file (in case of OLEDB) or a System/User/File DSN (in case of ODBC).
This article shows how to generate a connection string to connect to an Access database via the ODBC layer. (However, you can use a similar approach to connect to any database, also via the OLEDB layer.)
MathFour
AIMMS Partner
  • October 30, 2019
This is swell, but how does it work with the PRO platform?
