P_CMax’s original index domain is (c, t, w) but you replace t with tau (as it is another index in the same set) and limit the sum over tau to elements <= t.
tau <= t here will be equivalent to ord(tau) <= ord(t), assuming that your Set T is ordered i.e., t-1, t-2, t-3 … t-n
@mohansx
I am checking Thank you
I got the solution. Best regards
When solving the above problem, I am not getting the desired resolution. Declare: That belongs to the three Buses. Set Buses { Index: i, j; } {b1, b2, b2}
Then the parameters Parameter Susceptance { IndexDomain: (i, j); }
Now, you say j belongs to set i but the image shows j belongs to omega(i). What does omega(i) represent ?
In summary The problem has three nodes or buses, unit 1 is on bus 1 and unit 2 is on bus 2. Demand (triangle) on bus 3. finally there are three lines or links. Line 12 means that it is connected from bus 1 to bus 2. Line 13 means that it is connected from bus 1 to bus 3. Line 23 means that it is connected from bus 2 to bus 3. is where the problem is.
Now if I am on bus 1 there are two power flows that go through the lines, the flow that goes from bus 1 to bus 2, from bus 1 to bus 3. The same thing happens if I am on bus 2 now it is the flow that goes from 2 to 1 and from 2 to 3. mathematically it is the suscepatancia by the difference of angles.
so that would be the Omega set Ωi where i = 1,2,3 are the buses Ω1 = {2,3} Ω2 = {1,3} Ω3 = {1,2}
then I have the generation units set the Demand set. the set Nodes or buses (which has two indexes i, j)
the developed model would look like this:
my other idea is to declare the set Lines as: {Line1, Line2, Line3} or {1,2,3} or {Line12, Line13, Line23}
but as I tell AIMMS that Line1 goes from node 1 to node 2. Line2 goes from node 1 to node 3 and line3 goes from node 2 to node three.
It should be noted that the power flow goes in both directions 1 to 2, 1 to 3, 2 to 1, 2 to 3, 3 to 1 and 3 to 2 therefore the 3x3 matrix(3 buses) and the i and j indices.
Finally, as I declare that generator 1 is on bus 1, generator 2 is on bus 2 and the demand is on bus 3.
Already have an account? Login Please use your business or academic e-mail address to register
