copy one Section in Project A to Project B
  • September 14, 2024
  • 44 views
Can AIMMS achieve the function that copy one Section in Project A to Project B?  For example, there are two projects that need to use the energy storage model. I've built an energy storage module in Project A. How can I copy this module to Project B to avoid repetitive modeling?
Best answer by gdiepen
You could make use of either Libraries in AIMMS (https://how-to.aimms.com/Articles/375/375-library-function-procedure.html) or what I have used before to quickly share export/import certain identifiers from one project to another is using the “source” attribute of a section to write all identifiers within that section into a separate .ams file (and in the second project, read from that file). This part is explained in the howto article https://how-to.aimms.com/Articles/145/145-import-export-section.html
