Interpolation formula in AIMMS
  • July 17, 2024
  • 92 views
rahmat
Dear All,
I want to apply an interpolation formula to determine the value of a parameter. For example, a parameter that states the emission limit to achieve a net zero emission system has a value in 2025 of 1000 tons of CO2 and in 2050 the emission target is 0. How do I fill in the emission value between 2025 and 2050?
Thank you for the advice given.
Best answer by MarcelRoelofs
@rahmat
Assuming you have a set of Years with index y, then for instance
Emission(y) := 1000 + (ord(y) - ord('2025', Years))*(0 - 1000)/(ord('2050', Years) - ord('2025', Years));
would do the trick
MarcelRoelofs
  • July 25, 2024
@rahmat
would do the trick
rahmat
  • Ace
  • August 7, 2024
@MarcelRoelofs
Thank you for the suggestion.
