Overview: Deprecation of Compound Sets
  • Apr 1, 2019 9:39 AM UTC
  • 8 replies
  • 258 views
User Support
In May 2018 AIMMS announced a plan to deprecate compound sets in stages. Support for compound sets will be fully deprecated after January 1, 2020.
To find out how to identify and remove compound sets from your model without losing functionality, read AIMMS Knowledge: Prepare for the Deprecation of Compound Sets.
This article provides the following background information:
Here is the article
and here's how to prepare (and use set mappings)
Jess Es
  • Grand Master
  • Dec 6, 2019 10:21 PM UTC
FYI, the article has been recently updated/expanded by the author -
  • Adapted library for duplicate components in compound sets, for instance:
 Set s_Route {
SubsetOf: (s_Location, s_Location);
  • Adapted article to explain why the set Integers should not be used as a compound set component.
rahmat
  • Ace
  • Dec 17, 2019 2:03 AM UTC
Dear All,
I have difficulty to convert my model without any compound set. I included the model in the attachment of this reply. Any suggestion or help will be very meaningful for me.
Thank you very much.
Jess Es
  • Grand Master
  • Dec 17, 2019 10:32 PM UTC
Hi @rahmat - sorry to hear you’re having trouble. It can help if you tell more specifically what happened, and what you did so far. If you tried following the procedure from the article already, at what point did you get stuck or find problems? Thanks
rahmat
  • Ace
  • Dec 18, 2019 2:03 AM UTC
Hello Jess, thank you for you reply. I tried to do each step that explained in the link of preparation for the deprecation of compound set. When I did step 3 (create set mapping declaration), I got the error of “fncIndexForSet(): Unable to find index for set Bus” after I pressed the button Create Set Mapping Declarations.
Thank you
rahmat
  • Ace
  • Dec 20, 2019 5:39 AM UTC
Hello @Jess Es , thank you for your reply. I tried to do each step that explained in the link of preparation for the deprecation of a compound sets. When I did step 3 (create set mapping declaration), I got the error of “fncIndexForSet(): Unable to find index for set Bus” after I pressed the button Create Set Mapping Declarations.
Thank you
Chris Kuip
  • Dec 21, 2019 11:39 AM UTC
Hello Rahmat,
The set Bus is used twice in the set Line, therefore it needs two indices.
Please add index i2, next to the index i, for the set Bus.
With kind regards,
Chris
rahmat
  • Ace
  • Dec 23, 2019 2:11 AM UTC
Hella @Chris Kuip,
Thank you for your reply. It nicely worked and I didn't get the previous error. However, after I pressed the button of “Create set mapping declaration”, I was not able to locate “set mapping declaration” in my model as shown in the figure of step 4.
Thank you.
Chris Kuip
  • Dec 23, 2019 6:37 AM UTC
Hello @rahmat ,
Please check the end of the model tree for this runtime library:
With kind regards,
Chris
