Parameter for solving status
  • Jul 17, 2023 10:26 AM UTC
  • 108 views
Hi all, I am going to run the AIMMS with many different scenarios(case data) automatically. In case the solver may not find the optimum solution in some of the scenarios, I wonder is there any parameter or index (such as 0 or 1) I can get after solving each case to indicate if the solver has got the optimum solution?
Hi @Chunyang. You can use the math program suffix ProgramStatus for this. If it equals ‘Optimal’ then an optimal solution has been found.
