put.. only part of string in text file
  • June 4, 2019
  • 75 views
I have this code that prints the variables to a text file.
code:
for IndexVariables do
put(IndexVariables);
put // ;
endfor;
This prints only the first 12 characters of each variable.
Why is that?
Thanks, WM
Best answer by deannezhang
The default column width of put statement is 12. You can change it by :m, where m is the new width. for example
put IndexVariables:15;
put // ;
endfor;
deannezhang
  • June 5, 2019
put // ;
endfor;
