Questions about specific summation
Hello everyone,
I face some issues to implement a constraint on AIMMS.
Just to introduce you the problem:
Y(o,l,t) is a binary variable which is equal to 1 if a liquid l (a beer) is ready in tank o at period t;
Delta(l) is the fermentation time for a liquid l;
How can I implement this constraint?
Thank you for your help.
Regards
@amadeodum , you are right. You should use the ord function but only in the sum condition. The t-t’ in the variable will act as a lead/lag operator.
Try the below and let me know if that works as you expect or not
sum[(l,u)|ord(u)<=FermTime(l), Y(o,l,t-ord(u)] <= 1
  • April 12, 2020
@amadeodum , I assume you want this constraint to apply for all (o, t) and Delta(l) is a parameter? If yes, then the index domain of your constraint must be
(o,t)
Declare a second index t’ in your set of time periods as described here: https://how-to.aimms.com/Articles/184/184-use-multiple-indices-for-set.html
Now your constraint definition can be
sum[(l, t’)|(t’ <= Delta(l)), Y(o, l, t - t’)] <= 1
I am assuming that your set L starts from 1 and set T starts from 0.
  • April 12, 2020
@mohansx thank you for your answer.
Your assumptions are right, I forgot to mention it.
However, it does not work when I implement your constraint in AIMMS.
(I replace t’ by u and Delta(l) by FermTime(l)).
Shouldn’t I write the following code:
sum[(l,u)|ord(u)<=FermTime(l), Y(o,l,ord(t)-ord(u)] <= 1
Or does it change the meaning of the constraint?
Regards,
  • April 13, 2020
  • April 13, 2020
@mohansx It works!
Thank you for your help :)
