Select newest file, sort parameter
  • June 17, 2019
  • 125 views
I have an integer set, a parameter with filenames, and a parameters with Aimms'standard date/time.
How do I select the newest file, or how to sort a parameter and select the first, or how to select the smallest, largest?
@wiet
You can use the argmax and argmin functions to find the index which has the smallest / largest value.
So, Filename(argmax(i, dateparameter)) will give you the newest file / filename corresponding to the index which has the greatest (most recent date) value in the date/time parameter.
  • July 2, 2019
@wiet
