SetElementRename not working
  • Aug 8, 2024 10:51 PM UTC
  • 47 views
I am using SetElementRename to rename one of my elements. However, each time I run the function, it claims that the element is specified in the model and cannot be renamed, but this element is not hard-coded in any part of the model.
Has anyone actually got this function to work?
Best answer by Chris Kuip
Sure; I have positive experience using SetElementRename.
Please find enclosed a small app that illustrates the use of SetElementRename.
Operating this app:
first add a name, say "1” and press the primary action button in the lower right
Then click the new element in the table, and enter a new spelling for the element, say "One”, and press the primary action button again in the lower right.
The result is as follows:
As you can see, the element in the table is now renamed.
Hope this ensures you that the function SetElementRename works. However, if you have a problem using that function in your application, please share that with a project and detail what to do to highlight your issue.
When your project contains confidential information, please describe your problem in an e-mail with AIMMS User Support: support@aimms.com. Before attaching your confidential project to an e-mail; note that AIMMS User Support can provide you with a link for secure sharing of information.
With kind regards,
Chris
Chris Kuip
  • Aug 9, 2024 8:59 AM UTC
Operating this app:
With kind regards,
Chris
