The symbol ";" is not expected.
Good day people….i am new to AIMMS. I want AIMMS to read from a dat file but it keeps giving me the  statement “The symbol ";" is not expected.” The content of the dat file is
COMPOSITE TABLE:
G  M P R_M R_P
10 8 4 10  15 ;
after removing the symbol ; it pops up another error which is ‘The symbol "15    " is not expected.’
after removing 15, it pops up another error which is ‘The symbol "10     " is not expected.”
Is there something i am not getting right on how to structure the contents in dat file. Kindly help please.
Best answer by Chris Kuip
Hi Lawrence,
Parameters without an index domain are not supported by the composite table.  Please use assignments instead; for instance the following works:
G := 10 ;
M := 8 ;
P := 4 ;
R_M := 10 ;
R_P := 10 ;
A working copy of the project is included.
Hope that helps,
Chris.
Chris Kuip
Hello Lawrence,
I tried to reproduce the behavior you described, but failed; when you open the enclosed project, and press the ME button, the data is read in as follows:
After pressing the ME button in the enclosed app.
May I ask:
  1. Does this behavior persist after restarting AIMMS?
  2. Which AIMMS version are you using? (I am using AIMMS 4.86.8)
  3. If the behavior persists, how are G, M, P, R_M, and R_P declared?
With kind regards,
Chris.
  • July 6, 2022
Thank you Chris.
I am using 4.85.6.21.
G, M, P, R_M & R_P are declared as scalar parameters.
After restarting, it pops up the message below.
The file "Data\bottle" cannot be opened: No such file or directory.
Find attached the work folder.
Chris Kuip
Hi Lawrence,
G := 10 ;
M := 8 ;
P := 4 ;
R_M := 10 ;
R_P := 10 ;
Hope that helps,
Chris.
  • July 8, 2022
Thank you Chris.
It works. You could just help with the format to write to dat file. Thank you.
