Variable and constraint names in lp and sol files
  • February 7, 2020
  • 251 views
I was wondering if there is a way in aimms to generate sol and lp files using original variable and constrain names which are used in aimms modelling, or alternatively, to figure out the correspondence between variables in the sol and lp files and those in the aimms model?
Thanks
AIMMS cannot generate LP or solution files that are using the original variable and constraint names in the AIMMS model.
AIMMS will print a mapping between the variable and constraint names in the AIMMS model and the CPLEX model if you set the General Solvers option 'Solver Column Row Mapping’.
You can set options in the Option Tree, which can be opened by selecting Settings - Project Options in the menu bar.
