Reupload standard Excel functionality fails
Hi community
We use standard Excel functionality to download a file of the following format:
Then we try to reupload this file after having made the following adjustment (we manually adjusted the columns A and B and copied the values in A2 and B2 from other Excel):
However, this reupload resuts in 0 changes being made to the table in the WebUI. What could be the reason the reupload fails to read in the 1000?
Best answer by MarcelRoelofs
​@danileidelmeijer
My guess is because of the empty lines, which still hold styling information, but no data any longer.
Hello ​@danileidelmeijer, so you removed all the lines keeping only line 2?
Can you test by only editing the blue column?
Hi ​@gabiservidone, what I did was removing all lines, then pasting line 2 from another Excel to this Excel and reuploading. Indeed, if I edit only the blue column then things do go well. But why does the upload fail if I manually type (or paste) the values 20001 and 10007 in A and B?
MarcelRoelofs
​@danileidelmeijer
