How to pass initial solution in AIMMS for an MIP/ CPLEX
I am facing runtime issues for one of my AIMMS project. I am thinking to pass an initial solution to the model before we call solve statement.  As per the documentation, I have activated the following.
CPLEX X.X: Specific solvers > CPLEX X.X > General > Advanced start > Use advanced basis
I have stored the initial solution in an .xlsx file. I would like to assign this value to the variable. How to do it. I am not getting the options or idea.
Where to assign or how to assign if I would like to assign an initial solution to the following variable.
Best answer by Chris Kuip
You may want to use AimmsDEX to read in data from an Excel Workbook to a variable, as illustrated in the enclosed example.
Chris Kuip
  • June 6, 2024
Dear @Chris Kuip :
I am unable to open the AIMMS file. It is showing the following error. I am using AIMMS 4.85 version.
Chris Kuip
The enclosed project is developed using AIMMS 24.5 which can be downloaded from https://www.aimms.com/support/downloads/
