Adding an Initial inventory in AIMMS
  • Jul 10, 2023 9:21 AM UTC
  • 130 views
First, let me introduce myself (as its my first post):
Im and Industrial Engineer student making my end of master project studying the scheduling of a production plant. My tutor recommended me AIMMS to solve the MIP scheduling problem and, as you might have guessed none of us used this tool ever
So far so good, i have found a scientific paper that solves my particular problem ( i dont think i can upload the paper, so I’ll upload only the good stuff)
If AIMMS has a good thing its that it was easy (even for me) to introduce most of the constraints and definitions. So i made (most) of them
But theres one that particularly bothers me, restriction (2) and in a lesser way (7). This ones check the inventory stock at the the end of a certain T time, but if T=0, then it check It-1 (which it doesnt exist). And if T=1, it check It=0
The thing is that I created a Parameter that holds the Initial Inventory and i wanted to keep as close as the formulation previously showed, so i went ahead and made some “adjustments” that worked in my head, but didnt work in reality.
I havent used AIMMS, but i have some minor experience in coding, so you will probably see where I am going with that: If t-1>0, you check the constraint on Inventario_Final (Final Inventory on English) otherwise, you check over the parameter Inventario_Inicial (Starting Inventory).
But I have a nasty error that i cant solve. Maybe you experts could help me😉
Thx in advance
PD: as a bonus, here you have the files (in Spanish, that is, sry)
Hi @gmdaniel79. You can formulate this constraint using
Inventario_Final(i,t)
if t=First(Periodo) then
Inventario_Inicial(i)
else
Inventario_Final(i,t-1)
endif
sum((s), Asignacion_Lotes(i,s)-Prediccion_Demanda(i,t))
else
endif
  • Jul 11, 2023 7:45 AM UTC
Thanks @Marcel Hunting, it seems to work. 😊
I will do further testing soon, but so far so good
