WebUI Allocation problem result display
  • March 20, 2021
  • 112 views
I am dealing with the allocation problem where my result is a binary variable. In the application the result, the data filled in the variable, is presented in a nice way but I cannot get it to work in the WebUI. Is there a way to get this done ? When trying to display the binary variable in a table in the WebUI, no data is shown.
Kind regards,
Marie
Best answer by Anonymous
Hi @mariekravakova
Of course you can; this should work out of the box. From your post it’s is not quite clear where you get into trouble. Can you please check the contents tab of the widget (via cog-wheel of widget). Can you see your variable?
If you do, but you still can’t see values, please share your project here as any data you can see in the IDE data tables should be available in the WebUI as well. Also, as this is a binary variable it will show as check marks.
Be sure to zip the complete project folder; see https://how-to.aimms.com/Articles/45/45-share-project-files.html. If you are uncomfortable sharing it here, do send it to support@aimms.com referring to this post.
Table reference: https://documentation.aimms.com/webui/table-widget.html
  • March 21, 2021
Hi @mariekravakova
Andrew
  • April 7, 2021
Hi @mariekravakova
Did Gertjan’s answer help you with your problem?
